Cause of Delay
Roma Kolevatov
Joined Jun 26, 2018
8
Good evening!
Need help. Can't understand why the circuit doesn't work properly. (Please find pdf in attachments)
Brief circuit description:
Op-amps:
OA1 -- output voltage is the same as input = V. AO2 -- output voltage is the same as input = V. AO3 -- inverting amplifier: output voltage is --V. Тherefore, voltage drop between outputs of OA2 and OA3 is 2V. Purpose of other amplifiers is to measure voltage drop on R6. OA4 and OA5 send voltage drop on R6 to inputs of differential amplifier OA6 without change. And at the output of A06 we have (voltage drop on R6)*R10/R8.
Problem:
When I connect the circuit to voltage generator (sinus signal), I see nothing at the output of circuit (straight line). After waiting for ~15 min, sinus appears at the output. However, it is not a ''pure'' sinus, but sum of main signal plus some high-frequency sinus.
Question:
What is the cause of this delay? Where does the extra high-frequency sine come from? Any ideas?
Thank you!
Roma Kolevatov
Joined Jun 26, 2018
8
Why do you say AO3 output voltage is --V? According to your circuit, AO3 is an AC Op-amp Integrator with DC Gain Control, which produces a more complex output. As far as I concerned, the output signal is very dependent on time.
I think that AO3 is inverting amplifier: V_out=-R4/R3V_in. Note that the capacitor is in parallel to resistor, I connected this capacitor to reduce noises, it's recommended according to data sheet, but it's not compulsory. Current almost doesn't go through this capacitor. The same holds for the capacitor in the last differential amplifier, AO6.
By the way, I tried to disconnect all the capacitors -- nothing changes.
