I think I got second stage wrong.So, what is the voltage at the inverting input of the second opamp? Is it the same as the non-inverting input of the second opamp, or of the third?
Keep in mind that we seldom have a real clear picture of what you do and don't know, particularly regarding fine details. Sometimes a link to or a discussion of the basics fills in a gap that solves the problem. Sometimes it doesn't. When asking strangers for help, you're just going to have to accept that different strangers will provide different help based on what they think might move you in the right direction. Sometimes they'll be right on target, and other times they'll make a clean miss.I already knew what was said there, and that is still not what I'm asking for, so why are you posting useless links?
What are you tryng to amplify?Teknolog said:The purpose is just to construct a working amplifier chain. Then I'm going to test how the the amplification and phase changes for higher frequencies.
*Teknolog - if you know what an OTA is and how it works, why don`t you use the corresponding OTA symbol in your drawing?I already knew what was said there, and that is still not what I'm asking for, so why are you posting useless links?
Teknolog needs to clarify a point here.*Teknolog - if you know what an OTA is and how it works, why don`t you use the corresponding OTA symbol in your drawing?
But how can a voltage-based opamp "act as a transconductance amplifier" ?I've been assuming that all three stages use a voltage-based opamp but that the configuration of the second stage is such that the second stage acts as a transconductance amplifier ......
That´s what you were referring to? (I think, we shouldn`t confuse the OP).Consider the classic inverting amplifier configuration. Remove the feedback resistor and make those your output terminals. Place a load resistance (including a short circuit) across the output terminals and apply a voltage to the input resistor, Rin. What do you get? A current in the load that is proportional to the voltage. What's the transconductance of this amplifier? Simple, 1/Rin (or -1/Rin depending on how you have marked the output terminals).
I think WBahn answered this,Teknolog - may be somebody else can answer your question. I cannot.
I remember that you want to use a transconductance amp anywhere in the chain - and several times I have asked you to use the normal OTA symbol.
Otherwise, one cannot see if and at which place you intend to use an OTA.
What I see is the following:
A non-invertimg opamp amplifier in cascade with a unity gain amplifier and a classical inverting gain stage. All made of normal voltage opamps. Is it that what you want?
Also from Wikipedia:All a transconductance amplifier is is a circuit that takes a voltage between one pair of nodes and produces a current between another pair of nodes, correct?
You seem to be referring to this which is not what I'm using for this circuit.Transconductance amplifiers
A transconductance amplifier (gm amplifier) puts out a current proportional to its input voltage. In network analysis, the transconductance amplifier is defined as a voltage controlled current source (VCCS) . It is common to see these amplifiers installed in a cascode configuration, which improves the frequency response.
No - I don`t.You seem to be referring to this which is not what I'm using for this circuit.
I hope you understand what I mean now.![]()
You make me somewhat confused.Did you read the Wikipedia text I quoted? That's the kind of transconductance amplifier I'm using. As you can see it's called "transconductance amplifier". It doesn't matter if you missunderstood what I meant in my first post, that's what I'm using.
