Cascading three different amplifiers
Teknolog
Joined Sep 1, 2013
31
If I want to cascade a voltage amplifier, a transconductance amplifier and a transresistance amplifier, how should they be connected?
Would this connection work for example? The Load is the lower resistor to the far right.
33,325
This won't work because the load is in series with the feedback element of the transconductance amplifier.
LvW
Joined Jun 13, 2013
2,038
* The circuit has no common ground
* The second amplifier has no negative feedback
* The third amplifier has positive instead of negative feedback.
More than that - don`t forget that a transconductance amplifier has a current output (rather than voltage).
33,325
Oh, the second amplifier has negative feedback, and it is basically a transconductance amplifier in that the input voltage will determine the current flowing in the feedback resistor and, in this case, the final load. But the output current from the second amp will not be the same as the current in the feedback resistors, so the output of the second amp can't be considered a transconductance relationship to the input.
Let's say the input signal is 0.1V. The output of the first stage would be 1.1V. This would result in 1.1mA in both of the second stages feedback resistors which would result in 2.2V at the inverting input of the final amp. This same 1.1mA would flow in the load resulting in 3.3V at the output of the final amp. With 2.2V at the inverting input and 3.3V at the output, the current through the resistor going to the non-inverting input of the final opamp would be 1.1mA. This current would flow back and INTO the output of the second amp, so even though the magnitude of the current flowing out of the nominal transconductance amp is coincidentally the same as the current "returning" through the feedback network -- coincidental because change any of several resistors and that they will no longer be equal even in magnitude -- but it is in the opposite direction.
I think all of the feedback connections are in the right direction, but I'm not sure that there isn't a stability issue between the final two stages.
33,325
Notice that now your second stage is simply a voltage amplifier with a gain of 2. It has the same topology as the first state, right? The third state is now a comparator with positive feedback.
Teknolog
Joined Sep 1, 2013
31
Hm, right. I think I need some help designing this circuit. How can the transconductance amplifier at the same time give negative feedback and also have it's output current connected to the next amplifier?
LvW
Joined Jun 13, 2013
2,038
1.) Is the second amplifier an OTA? In this case you should use a corresponding symbol
2.) What is the reason for positive feedback of the last stage? It will not work as expected.
3.) Still the common ground is missing (one can imagine where it is).
Teknolog
Joined Sep 1, 2013
31
shteii01: I don't think that works, looks to me as if you've switched places of the load (third op circuit) and the resistor in the second amplifier. Also I'm thinking the output of the second amp should go into the - input of the third?
LvW: I want to use the op amp "TL071" in all three stages.
I still haven't figured out how to connect them. Any help with circuit design for the second and third amps is welcome.
Teknolog
Joined Sep 1, 2013
31
No OTA anymore? And what is the purpose of the whole amplifier chain?
You want help for the 2nd and 3rd amplifier - but we do not know what your intention is.
The purpose is just to construct a working amplifier chain. Then I'm going to test how the the amplification and phase changes for higher frequencies. But first I need to construct a cascade chain that works like intended (i.e. One voltage amp, one transcond. amp and one transres. amp).
Teknolog
Joined Sep 1, 2013
31
Would this connection work? I made it so that there's negative feedback in the second op amp but it comes all the way from the third op amp. Also the third op doesn't have common ground. I don't know how to connect it otherwise though?
Alternatively, it would be
Here they have common ground but the second op amp doesn't have negative feedback.
Doesn't anyone know how to do this???
33,325
I think second stage should look like this. The third stage is the load resistor of the second stage.
So, what is the voltage at the inverting input of the second opamp? Is it the same as the non-inverting input of the second opamp, or of the third?
@OP: Draw each stage differently, clearly identifying the input and output for the stage. Then it should become fairly apparent how they can be interconnected or whether there are issues with the connections that would be needed.
