Carpenters mistake which way to replace wires
DVF
Joined Nov 8, 2017
8
My clock/radio was working intermittently with what I thought was a broken wire, where the power cord entered the body. I foolishly didn't keep track of wire colours when I melted the solder connections to remove the power cord. Can anyone help with which way the black and white wires from the power cord are supposed to be re-soldered, please? Is the black on the right or left (on the soldering side)? If I was a guessing man I'd say the rectangular box indicates black on the left because the 1 in the box indicates 'power', right or wrong?
About the pictures: pictures of the same end of the circuit board, front and back. Top pic: GCI 1V0 94V-0 cn301 Bottom pic: SONY P301 ICF-c793 1-716-151-12(2) 1-671-842-12 P7 07 99.02.02 T301
THANKS TO ALL WHO REPLY!
ian field
Joined Oct 27, 2012
6,536
THANKS TO ALL WHO ANSWER!View attachment 138929 View attachment 138930
Is that a gigantic solder blob pretending to be a booger between 2 pads; bottom left near the connector?
DVF
Joined Nov 8, 2017
8
Is the power plug polarized?
Thanks for the interest in my problem, dl324. By polarized I think you may mean the plug end? with one blade larger than the other? If thats what you mean then yes, polarized. If its not the plug end you refer to then I don't have enough knowledge to answer.
I guess my answer got deleted with the duplicate post I reported!
Max.
Maxheadroom, you're forgiven! I duplicated the post thinking I would get better visibility with two posts. Looks like it worked :)
DVF
Joined Nov 8, 2017
8
Ian: thanks for the interest in my problem, and yes quite some booger there. Original from the factory I think. Radio has been reassembled and seems to still work fine.
Good idea to clean the "snail trail" of flux where it ran down the board, before giving up and try hoodwinking the warranty department.
Yes, that looks like it needs fixing.
Albert: Thanks for the reply. I think that solder blob is original from the factory and has worked well for 20 years. Radio is together after my power cord fix and seems to be working fine.
AlbertHall
Joined Jun 4, 2014
12,653
There is no switch between the inputs to that board and the transformer primary.
Clock radios don't generally an on/off switch. Why would you want to turn off a clock?
DVF
Joined Nov 8, 2017
8
Albert, the radio is switched, an on/off button, but not the clock. Most clock radios have switches for the radio.
dl324
Joined Mar 30, 2015
18,455
Albert, I'd have to agree with you on this, because it just makes sense to me, a carpenter. Thanks again for your interest in solving my problem.
If there is no power switch, then the polarity of line and neutral doesn't matter. With a power switch, the hot wire needs to go to the switch.
SLK001
Joined Nov 29, 2011
1,549
It doesn't matter which way the wires go.
If you had taken the time to completely fill out your user profile, we would know what country you are in and also the line input characteristics. But in this case, it doesn't matter - either way you connect the power it will work. By work, I mean that the voltage will be dropped to the required input to the circuitry - whether or not the circuits are working properly remains to be seen.
