Not very likely for an established company. More likely with a startup company; the downside of that is you need a way to support yourself until the company starts making money.Hi
do IT companies hire people with programming skills but without any certificates or college degrees?
If you have a strong portfolio of work you can show them, then they are much more likely to overlook the lack of professional credentials. If you haven't already, start putting some of your best work on GitHub and make that available to the companies you apply to.Hi
You may or may not be able to give insight to the TS's question from a valuable perspective. You became a software engineer but weren't hired as one. Without the degree credentials, how hard do you think it would have been for you to get hired with a different company (one that didn't know your and your work) in a software engineering, or even more basic computer programming, position?I do not have a degree in computer sciences. I was hired as a tech to repair and install PCs for my company. I installed purchased software that I had no input on the purchase. It turned out to be a piece of garbage and we likely paid a small fortune for said garbage. I rewrote the application in less than a month. I have been working as a software engineer for my company ever since.
Why is that Difficult and not likely?;Hi
Not likely if you want to work at a large company. Unless you have years of experience, all they have to go on is your education and grades. They don't like to make hiring mistakes because it's difficult to get rid of someone; assuming you get past the probationary period.do IT companies hire people with programming skills but without any certificates or college degrees?
