I will be in France in September. I will take my tape measure with me and report back.Shouldn't there be a parameter for "Eifell Tower Height"?
When I was working at NIST designing measurement systems, one of the things we always had to keep in mind is that everything is a thermometer, whether you want it to be or not.Makes you wonder if you lived somewhere in Paris from where you could see the Eiffel tower and owned some surveying instruments whether you could work out the temperature.
For France, I hope it's in metric!I will be in France in September. I will take my tape measure with me and report back.
Only if you use TV-show grade image enhancement.
As they say, all you need to measure the height of a tower is a metre ruler, a barometer, a thermometer, and a long piece of rope.For France, I hope it's in metric!
You could throw something off the top and time it, but that would be affected by the air resistance which would change with temperature.As they say, all you need to measure the height of a tower is a metre ruler, a barometer, a thermometer, and a long piece of rope.
Of find someone that knows the height of the tower and offer to sell it (the tower) to them in exchange for the information. ;DAs they say, all you need to measure the height of a tower is a metre ruler, a barometer, a thermometer, and a long piece of rope.
Edit: and a stopwatch.
The answer depends on the assumptions allowed. Nearly all "physics questions" require assumptions and the reasonableness of the assumptions depends on the required fidelity of the answer. For this case, it depends on what "the same time to fall" means? If the time of one is within 1% of the other, is it close enough to be considered "the same"? Or, does ANY difference, even a picosecond, qualify as being not "the same"?Here is a physics question.
Would a small steel sphere and a much larger steel sphere 1000 times heavier take the same time to fall to the ground from the top of a tower?
I don't know but I'm betting the larger one will cause more property damage.Here is a physics question.
What is alarming is that, with misinformation as rampant as it is, this is no longer is obvious.https://berkeleybeacon.com/onion-ceo-confirms-the-onion-is-in-fact-fake-news/
Onion CEO confirms The Onion is, in fact, ‘fake news’
| Thread starter | Similar threads | Forum | Replies | Date |
Anything (not so) obviously wrong with this latching relay toggle? | Analog & Mixed-Signal Design | 12 |
