Hello. If I have two 30F capsitor rated for 6volts in series with each other will their voltages add up to be able to handle a 12 volts power supply. Thanks.
Is that 30 Farad, μf, or pf?Hello. If I have two 30F capsitor rated for 6volts in series with each other will their voltages add up to be able to handle a 12 volts power supply. Thanks.
30 farads??? Check that to be sure.Hello. If I have two 30F capsitor rated for 6volts in series with each other will their voltages add up to be able to handle a 12 volts power supply. Thanks.
