Capacitor sizing for no-Amp load - Bridge Rectifier
jagermini
Joined Dec 19, 2017
Hi folks!
I've got an alternator providing 3 phase voltage at 12.4V AC. I'm putting one of these phases through a full wave rectifier diode bridge, which brings it down to around 11V DC or thereabouts.
This is then going through a voltage divider, and into an Arduino to measure voltage.
I can't find any formula for capacitor size calculation to smooth out the ripple of the regulated voltage, that doesn't include current. Since I'm sending it into an Arduino, I believe there is no current draw.
Is there another formula to calculate this, without needing a current value?
Or can I just stick in a 100uF capacitor and expect it to do a reasonable job??
jagermini
Joined Dec 19, 2017
Hi Eric!
I'm using a 3.3kOhm and 9.1kOhm to bring the 11V DC down to around 3 Volts for the Arduino.
Those figures are approximate as I don't have my notes with me, but it's as indicated, or very close.
ericgibbs
Joined Jan 29, 2010
16,421
hi j,
With 100uF and a low 50Hz this is the ripple level.
E
Update: @jagermini
I guess you know that when your 12.4Vac is full wave rectified and smoothed the Vcap = (12.4v *1.4) - 2*Vdiode voltage drop = ~16Vdc, so the 9k1 resistor value will have to be increased to ensure the Arduino input is still 3Vdc.? Change the 9k1 to 15k
jagermini
Joined Dec 19, 2017
Ok, cheers guys for the responses. Yep, the current through the voltage divider, that is a fair point, had not occurred to me......!
I'll have a look at those links, thanking ye!
