Capacitor ID
twister007
Joined Feb 29, 2012
93
I have some capacitors that have the numbers 102, 103 and 104. What are their values and how do determine the values. I couldn't find a source online.
dl324
Joined Mar 30, 2015
18,326
The first 2 digits are the significant digits and the 3rd is the multiplier; they represent the capacitance in pF. 1000pF (1nF), 10,000pF (0.01uF), and 100,000pF (0.1uF), respectively.
From AVX:
twister007
Joined Feb 29, 2012
93
Many thanks to everyone who replied! They changed the way my older ones were marked, like .1, .01 and .001!
SamR
Joined Mar 19, 2019
5,487
Yes, I have a prior version of it and have compared its reading to both my 5 1/2 digit bench meter and a dedicated LCR meter (both after zeroing good to within a couple of pFs) and it is pretty accurate. Not research equipment but good enough to sort parts with. They are cheaper if you cut Amazon out of the middle and get them direct from china by AliExpress if you can wait 6 weeks or so for delivery.
Actually this is the one I have and it has a rechargeable li-ion battery and smaller size. Also does inductors and a couple other tricks. From AliX
EDIT: Also, be very careful and read the ad closely as there are similar looking older units (TC-1) that are not up to date and have less functionality! One good hint is the price as the older units are cheaper. They do work fine, just not as full featured.
JohnInTX
Joined Jun 26, 2012
4,787
On the same note has anyone tried on of these.
I have that one under the DROK brand name. It’s useful for quick tests and the numbers compare favorably to my other high dollar LCR meters. The component ID is handy. I don’t know if this one is a clone of a clone but the DROK seems OK and I have a few other DROK gizmos that work OK as well. You give up input protections, control over operating frequencies, voltages etc., and calibration traceability but it’s a fun gadget.
SamR
Joined Mar 19, 2019
5,487
I think they are all made in the same plant in china under several labels as are many china products. I actually have ~4 of them of different vintages and abilities. Early models W/O cases the later models had. They keep making them better and with more functions and larger screens as time goes on.
MB107
Joined Jul 24, 2016
400
There were several of them on Amazon that all looked the same but had different brand names.
