Capacitor Equivalent
Wolframore
Joined Jan 21, 2019
2,619
The circuit drawn is unreadable... can’t make sense the flow of current. You might try the 10 uF, there’s 10-20% tolerance on those parts.
Sensacell
Joined Jun 19, 2012
3,789
That schematic will NEVER be ok, it breaks every rule of schematic drafting.
Pictorial schematics are a really bad idea, they do more harm than good.
It's the equivalent of emoji and text abbreviations instead of clear english.
spike1947
Joined Feb 4, 2016
537
Hi
Thanks for your reply, it really matters if you can understand the circuit, not sure what you mean " Text abbreviations", the only one I can see if that is an abbreviation, is the letter "N" meaning Neutral ! .
PS: I am not a Electronic Engineer, just a common Electrician trying to stop stuff going to landfill .
Cheers and thanks for looking anyway.
Spike
spike1947
Joined Feb 4, 2016
537
https://hackaday.com/2019/03/19/ask-hackaday-how-do-you-draw-schematics/
Here are some starting points to drawing schematics.
The rules are simple, and you don't need to learn EVERY component symbol to get started, just the basics.
it's the international language of electronics, it's very precise and communicates ideas clearly.
Hi
Thanks for that, I would just need to make sure that the info in my original drawing is correct for me to convert to a proper schematic, I have a couple of programs I can use (Autodesk Eagle premium and DipTrace ) have them but not used them , I done the one I posted on here with Smartdraw ! , but obvious I wasn't very smart using it !
Wolframore
Joined Jan 21, 2019
2,619
Imagine if everyone made their own way of notating music or system of alphabets? It would be more cryptology than communication. A standardized format makes communication clear so we can quickly and easily see what's going on in the circuit. Do what you like for your own circuits... use pictures, short hand.... etc. but you may find that the convention works very well even if you went back after years of seeing the circuit, it is apparent without wondering what the pictograms are conveying.
spike1947
Joined Feb 4, 2016
537
Wolframore
Joined Jan 21, 2019
2,619
It's a step in the right direction... There are some issues with it.
1. You should connect all the lines especially if it fits on the same page.
2.The BJT should be connected and not just labeled.
3. Label your voltages - AC1 - what does that mean? 120V, 240VAC... 24VAC???
4. Use a ground symbol to indicate ground... this way they do not all need to be connected
5. Values matter - label the resistor, cap, vales and include part numbers... I have no idea what those Zener voltages are
Good try, hopefully you're take this as feedback that helps you improve and not an attack.
I would love to hear the reasoning behind all the diodes in your circuit. I haven't combed through it but on a quick scan it looks excessive and unnecessary. Here's a cropped version which makes it easier to see and read:
spike1947
Joined Feb 4, 2016
537
Hi
Thanks for the feedback, was keen to post to see if I was getting somewhere.
Cheers and thanks again for having the time to look and comment.
Spike
spike1947
Joined Feb 4, 2016
537
Hi
I hope this is a better one, I have not connected the Transistor because I am a little confused as to the connection I think is a PNP but it does not seem to fit the flow of the drawing , could be wrong, the lettering are correct as i Emitter,Collector,Base.
I could not really fit the Motor winding into the drawing I am sure there is a way to enlarge the sheet to do that !, so I have just really botched cramming it into the drawing .
Any comments as to if there is any mistakes in it would be highly appreciated .
cheers
Spike
28,626
Whoever drew that "schematic" should stick to their day job. I have no idea what it does and won't even try.
The circuit appears to be for a shredder and the capacitor appears to be connected across a relay coil as a chatter preventer. it may also affect the operating speed of the stall detector.
Why are you wanting to replace that capacitor? I would try to get one closer to the original value for that location. A higher voltage rating would be OK, though.
And the total panic mode of the comments about working with a 240 volt circuit is really out of place. Once an individual knows how to work around live circuits they can do it safely. In addition, did the TS ever say they were working on it live? I may have missed that because of all the noise about the drawing.
28,626
While the pictorial circuit was non-conventional it was quite possible to follow the circuit and see what was going on. The attack pile-on was certainly not needed.
And I am still wondering why the TS believes that capacitor needs to be replaced.
spike1947
Joined Feb 4, 2016
537
This was the original post .
“ Paper Shreader Fault, not running”
Switched it on then I was getting my meter out to test voltages , when I heard a buzzing sound so switched it off, then I switched on again to see what it was that was buzzing ,while I was listening it started up, held the 2 IR bulbs next to each other and it stopped, pulled them apart and the buzzing started then it started to run
I clipped the IR bulbs next to each other with a gap put a piece of paper in between nothing straight away, after a couple of seconds again it started to buzz then it started up ! “
Was informed to replace the 3 E Caps .
Spike
Wolframore
Joined Jan 21, 2019
2,619
It’s better because more things are labeled, if you want to improve your skills recommend studying other schematic. It’s not bad for reverse engineering a board... I had forgotten that we were trying to fix it. Did you try your caps?
