Capacitor Equivalent
dl324
Joined Mar 30, 2015
18,524
I have drew it has per the actual PCB !
With D5 in the orientation shown, Q1 can't turn on. The connections to the body of R15 have to be wrong.
When we draw schematics, we draw them so that circuit function can be discerned. We draw wires using multiples of 90 degrees unless it's an exceptional case (e.g. flip flop).
spike1947
Joined Feb 4, 2016
537
Yes sorry about that, could not flip the Q1 for the correct orientation
spike1947
Joined Feb 4, 2016
537
Q1 still can't turn on with D5's anode on its collector.
Ok , thanks for that will have to " Go back to the drawing " as they say, another reason for maybe it not being correct , is the info is taken from the bottom looking up !, will revise and come back , thanks for all your replies .
cheers
Spike
Wolframore
Joined Jan 21, 2019
2,619
Is this for an AC circuit for US or outside of US? The cap is a bypass for the emitter, provides decreasing impedance as frequency goes up to the common emitter which is strangely conducting on the negative cycle. What’s the part number of that transistor?
spike1947
Joined Feb 4, 2016
537
Hi
Thanks for your reply, 240v, UK voltage , Transistor A44-331 .
Spike
