Can't get beep-beep-beep !
AlbertHall
Joined Jun 4, 2014
12,652
The capacitors used in this design are polarised - they need to be connected the right way round or they will not work. The diagram shows them the wrong way round. The positive wire of each capacitor should connect to the collector of the transistor and the negative shoud connect to the base.
Jewelkhan
Joined Aug 17, 2017
5
thank you mate. tonight i will try and post result. should i alter LED polarity too ? COZ i see positive cap polarity connected to the LED negative!
JoeJester
Joined Apr 26, 2005
4,390
What is the model number of your motion detector receiver?
You can test your annunciation circuit pretty easily.
You can put the 5 volts at the 5V point as well as the Enable point (where the IR detector will go eventually). If your circuit is as drawn, your buzzer will sound at approximately 18 Hz. If the alarm is constant on when you energize it with 5V, the circuit will pulse that sound at an approximately 18 Hz rate.
Are you attempting to replicate the instructable or do you have your own design specifications in mind?
The pdf is what I think you have for a motion detector. You can confirm or deny.
AlbertHall
Joined Jun 4, 2014
12,652
Good point. With the values given it will not 'beep, beep, beep' it will warble continuously!
To make it sound like the one in the video the two capacitors would need to be 100uF - 200uF.
