hello everyone,
i was trying to write page in eeprom 24c04 using ATMega32
the problem is when i m trying to write 255 character its working fine with the code. i can write using the page write function i have build and i can read the string from eeprom too.
but when i try to read mode than 255 characters, display shows garbage
here is my twi.c file
this is how i'm doing page write
and this is how i'm reading the string
So when i first approached this problem i thought 24c04 takes 16bit address value and i'm just provideing with 8 bit address value while writing in page and reading the string.
so i did this
but unfortunately the problem does not solve.
any help will be extremely helpful.
thanks in advance
C:
#include "twi.h"
void Twi_Init()
TWSR = 0x00;
TWBR = 0x02;
unsigned char Twi_Start(void)
TWCR = (1<<TWINT)|(1<<TWSTA)|(1<<TWEN);
while (!(TWCR & (1<<TWINT)));
return (TWSR & 0xf8);
while((TWSR & 0xf8) != 0x08);
unsigned char Twi_Repeated_Start(void)
while((TWSR & 0xf8) != 0x10);
unsigned char Twi_Send_Address(unsigned char addr)
TWDR = addr;
TWCR = (1<<TWINT)|(1<<TWEN);
while(((TWSR & 0xf8) != 0x18) || ((TWSR & 0xf8) != 0x40));
unsigned char Twi_Send_Data(unsigned char data)
TWDR = data;
TWCR = (1<<TWINT) |(1<<TWEN);
while((TWSR & 0xf8) != 0x28);
unsigned char Twi_Send_String(unsigned char *string)
while (*string)
TWDR = *string++;
unsigned char Twi_Receive_Data(void)
TWCR =(1<<TWEA)|(1<<TWINT)|(1<<TWEN);
return(TWDR);
while((TWSR & 0xf8) != 0x50);
unsigned char Twi_Receive_Last_Data(void)
TWCR =(1<<TWINT)|(1<<TWEN);
return(TWDR);
while((TWSR & 0xf8) != 0x58);
unsigned char *Twi_Receive_String(unsigned int number_of_bytes,unsigned char *string)
for(unsigned int i=0;i<number_of_bytes;i++)
*(string+i)=TWDR;
*(string+number_of_bytes)=Twi_Receive_Last_Data();
*(string+number_of_bytes)='\0';
void Twi_Stop(void)
TWCR = (1<<TWINT)|(1<<TWEN)|(1<<TWSTO);
while ((TWCR & (1<<TWSTO)));
C:
void EEP_PageWrite(unsigned int starting_memory_address, unsigned char *string)
unsigned char page_value;
page_value = 16;
Twi_Start();
Twi_Send_Address(EEP_W_Address);
Twi_Send_Data(starting_memory_address);
for(unsigned char i=0;i<page_value;i++)
Twi_Send_Data(*(string+i));
Twi_Stop();
C:
unsigned char *EEP_ReadString(unsigned int starting_memory_address, unsigned int number_of_bytes,unsigned char *string)
unsigned char twi_status;
Twi_Start();
Twi_Repeated_Start();
Twi_Send_Address(EEP_R_Address);
Twi_Receive_String(number_of_bytes,string);
Twi_Stop();
return string;
so i did this
C:
page_value = 16;
Twi_Start();
Twi_Send_Data(starting_memory_address>>8); //added this line
Twi_Stop();
Twi_Start();
Twi_Stop();
return string;
thanks in advance
