Thanks crutschow this is very helpful. With this circuit the THD is 1.67%, is that a lot of distortion?Here's the circuit from post #14 with some local emitter negative feedback in the last stage, which significantly reduces the distortion.
To view the harmonic distortion percentage, use the .four command as shown, and look in the View/Spice error log after doing the simulation.
Such feedback in the first stage should give a further reduction in distortion (with a reduction in gain that negative feedback always gives, of course).
I then modified the circuit by adding some negative emitter feedback to stage 1. The THD dropped to 0.61%.
Finally, I added two-stage feedback and that reduced the THD to 0.16%.
2019
