I'm trying to reset a PIC18 by a direct connection from MCLR to ground, but cannot get it to work. Circuit attached. The MCLR pin is enabled.
Sorry.. forgot to indicate values. 10k resistor and 100NF cap. Yes, the MCLR enable bit is on. It is QFN.Did you set the MCLR enable bit in the config word? I have no idea what value your R1 is...Is it close to 10K? Are you indeed using the QFN package part?...Different packages have different MCLR pin numbers.
Thanks for not replying my post.Sorry but your "schematic" sounds strange to me.
C1? C2? Would you mind drawing that part by hand?
