Can you help me find a replacement for this Diode ?
Lumenosity
Joined Mar 1, 2017
614
Slow going and a work in progress but here the schematic around the IC that has the face all shaved off so it can't be identified.
D8 is the Diode in question. This IC chip has just barely enough on the face left to tell it is from SEC. same as the other 2 IC chips.
Lumenosity
Joined Mar 1, 2017
614
U1 - KA7500B or TL494
U2 - LM324
U3 - KA7500B or TL494
D8 - 1N4148
On further review.....
The KA7500B is a Switching PWM Controller,
https://www.mouser.com/datasheet/2/308/1/KA7500B_D-2314474.pdf
So is the KA5325A
https://www.mouser.com/datasheet/2/308/1/KA3525A_D-2314508.pdf
Would it make sense that this simple board has two IC's performing that same functions ?
The 3 IC chips on this board again are.....KA3525A (PWM Controller), KA324 (Quad Op Amp) and an unknown DIP-16 IC chip
Lumenosity
Joined Mar 1, 2017
614
U2 - LM324
D8 - 1N4148
The device is a 300watt Modified Sine Wave DC-AC inverter
It has these two chips that I can identify.....
KA3252A - PWM Controller
KA324 - Quad Op-Amp
Given these two chips in the circuit, I'm trying to determine the identity of the 3rd chip
It was suggested that it might be a KA7500B but that is a PWM controller that performs similar functions to KA3525A.
The TL494 is also a PWM controller.
So is the KA5325A
Would it make sense that this simple board has two IC's performing that same PWM functions ?
What other functions could that 3rd chip provide that the other 2 don't already?
That said, after reviewing the schematic, I see some connections to the unknown IC that are identical to those for a SG3525
