@ericgibbs pointed out the radiation pattern of a loop but in addition the polarization is important as well. There are vertically and horizontally polarized loops though the radiation patters just stays relative to the polarization as you’d expect.Perpendicular or Horizontal makes no difference.
That figure and explanation is incorrect.
For a loop antenna, Maximum pickup is on Broadside, Minimum along the Plane of the loop.
I agree with you, It's a UHF bowtie (type) antenna with a classic bow-tie reflector AND a VHF dipole.As far as I can tell, despite the appearance this is not a loop antenna. You can see the horizontal dipole behind the "loops". The description says it is "multi-element", so something different is going on inside those radomes.
It is a very highly rated antenna, mostly considered the best dual band apparently.
I wonder if it is a variation of a bowtie antenna.
That's what I thought, even though the manufacturer calls it a loop. I would love to see under the radomes and the feedpoint.I agree with you, It's a UHF bowtie (type) antenna with a classic bow-tie reflector AND a VHF dipole.
If it was a bow tie it would be vertically polarized. I suspect it is approximately an array of resonant loops which, in that configuration, would be horizontally polarized.I agree with you, It's a UHF bowtie (type) antenna with a classic bow-tie reflector AND a VHF dipole.
It could be a tapered loop.If it was a bow tie it would be vertically polarized. I suspect it is approximately an array of resonant loops which, in that configuration, would be horizontally polarized.
The specs I've seen aren't that good, but it looks trendy. I suspect that simple arrays of bow ties would have better specs. So I think it is sold as a fashion statement rather than as a triumph of antenna engineering.
I've also seen this picture with VHF capability:
Whilst I'm no expert on US TV polarization conventions, my guess is that both UHF and VHF are horizontally polarized in that configuration.
Never knew that. Can you please direct me to any tutorial were I can learn about it ?If it was a bow tie it would be vertically polarized. I suspect it is approximately an array of resonant loops which, in that configuration, would be horizontally polarized.
A dipole receives efficiently at a frequency determined by its construction length; which whatever it is, does not cover 50 to 220 MHz. Cannot understand how a single non-telescopic VHF dipole is meant to receive 50MHz to 88MHz and 170MHz to 220MHzIt's a UHF bowtie (type) antenna with a classic bow-tie reflector AND a VHF dipole.
The key words are efficiently matched for power transfer. It's most efficient when matched at resonance but will work as a voltage source of a usable rf receiver signal over a much wider range.A dipole receives efficiently at a frequency determined by its construction length; which whatever it is, does not cover 50 to 220 MHz. Cannot understand how a single non-telescopic VHF dipole is meant to receive 50MHz to 88MHz and 170MHz to 220MHz
Light, please.
Jasik - 'Antenna Engineering Handbook' - Chapter 5 in my edition. You can find it online.Never knew that. Can you please direct me to any tutorial were I can learn about it ?
When you mention "resonant loop" at what frequency resonates ?
| Thread starter | Similar threads | Forum | Replies | Date |
Samsung LED TV showing double image | Technical Repair | 3 | |
Acer V227Q (AUO Panel) - Vertical lines & image freezing every 2s. Mainboard/LVDS replaced. Which T-CON test points to check? | Technical Repair | 1 |
