Can the lithium battery be charged?
Young2
Joined Dec 7, 2020
93
My LCD uses lithium batteries, although the power supply for the screen is through the power supply, if the battery is not charged seems to be no way to back up, just in case, I want to know first lithium batteries can be charged? If so, how to charge?
AlbertHall
Joined Jun 4, 2014
12,653
There are rechargeable lithium button cells available but the 'CR' on the cell in your picture implies that it is a primary cell - not rechargeable - and so needs to be replaced when it is flat.
Young2
Joined Dec 7, 2020
93
So I just need to buy the exact same battery as it and replace it when it runs out of power?
Ya’akov
Joined Jan 27, 2019
10,307
Yes, you need to use the same button cell but it should last a very long time. Any circuit in a commercial product using such a cell would be drawing very little current. Sometimes, it is barely above the self discharge rate and the cells are generally rated for a 10-year shelf life.
ericgibbs
Joined Jan 29, 2010
21,583
hi,
There are LiR 2032 rechargeable types, but they are rated at 3.6V.
You would have to add suitable charger circuit, the regular CR2032 would be easiest option to replace.
BTW: In case you did not know the 2032, means 20mm Dia and 3.2mm Thick.
E
Clip:
1 x CR2032 Li-ion rechargeable button cell battery 3.6V Lir2032 replaces all CR2032 Lithium 3V. Very cost-effective: A rechargeable CR2032 replaces 200 lithium CR2032 disposable battery cells Capacity: 40 mAh rechargeable 500 times. Dimensions: 20 mm x 3.2 mm. Weight: 2.6 g. Compatible models: CR2032,
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjh1rmt8ofyAhUZHcAKHa9-AcIQFjAAegQIBxAD&url=https://www.amazon.co.uk/CR2032-Li-ion-Lir2032-Rechargeable-Battery/dp/B00LPEFFNW&usg=AOvVaw1Yg0bGG5CjTq_JLru_nR4L
Ian Rogers
Joined Dec 12, 2012
1,136
The charge circuit for a rechargeable is minor... Couple of diode and resistor.. This circuit will be in the LiR2032 datasheet.
If you use rechargeable, then you can put a much smaller battery in..
Young2
Joined Dec 7, 2020
93
hi,
E
Clip:
Thanks for your enthusiastic reply, I will check it out and buy some.
