Can someone help me with part a of this problem?
Status
Not open for further replies.
panic mode
Joined Oct 10, 2011
5,417
in this problem diode conducts if Va-Vk>=0.6V but for the sake of analysis of this problem, we only need to solve what happens when diode(s) are forward biased. that is when Vi<=5V-0.6V or more specifically when Vi is in range [0V,5V-0.6V)
linhvn
Joined Nov 6, 2024
297
I dont know what you mean, it seems that it is off the practice problem.
panic mode
Joined Oct 10, 2011
5,417
since Vf=0.6V, diodes are not conducting when Vi is in range [4.4,5.0]. supply [0V,5V] so all that is left to solve is subset of that range, which is when Vi is [0V, 4,4V). singe gate has at least two inputs (and generally it could be more), Vi input that matters is the lowest one.
when inputs are high, output is simply 5V (no current through resistor)
and if one of more inputs are low, then we only need to look at one with the lowest voltage.
for example
V1 = 2V
V2= 1.7V
since V2 <V1, we only need to see what is happening with V2.
Vo1 in this case is
Vo1 = Min(V1,V2) + Vd = 1.7V + 0.6V = 2.3V
then we apply the same on the next gate and so on... you can solve 500 gates in 10min. to do that by applying giant KVLs would take lifetime..
dl324
Joined Mar 30, 2015
18,490
@dl324 can you continue your guidance steps?
Replaced the diodes D1 and D2 with very large resistances and solve the loop equations. Then do the same for the other gate.
And, yes, using KVL makes the solution more tedious; but you need to start somewhere. It's easier/faster to just look at the input voltages and determine what the output voltage is.
linhvn
Joined Nov 6, 2024
297
Why replace them with very large resistances ? Can I let D1, D2 open circuit?
If I replace them with resistances like below, which loop should I write, blue one or red one? tks
linhvn
Joined Nov 6, 2024
297
for example
V1 = 2V
V2= 1.7V
Vo1 in this case is
in the practice problem, V1=V2=5V, then Vo1 = Min(V1,V2) + Vd = 5V + 0.6V = 5.6V, right?
WBahn
Joined Mar 31, 2012
33,309
As usual, you need to go back and put in some effort at learning the fundamentals.
Because you won't, you are once again blindly assuming that the voltage across a diode is 0.6 V regardless of whether that makes any sense whatsoever. As a result, you get a nonsensical answer and have no ability to spot that it makes no sense. Consequently, you just keep digging yourself deeper and deeper into that hole you seem so fond of.
Getting a result that the voltage anywhere in this circuit is 5.6 V should have thrown up all kinds of red flags. How can a circuit like this, that has nothing greater than 5 V anywhere, produce a voltage at V01 that is 5.6 V? If it did somehow do that, what direction would current be flowing in all of those resistors? Where would that current be coming from?
boostbuck
Joined Oct 5, 2017
1,066
If all the supplies are 5V, where is the extra 0.6V coming from? Does a diode GENERATE voltage? No, it has an innate voltage drop when current flows through it.
linhvn
Joined Nov 6, 2024
297
The blue and red paths are the same, but you came up with 2 different answers.
If V1=V2=5V, there is no current flowing in the resistors. What is the voltage between the two resistors (at V01)?
no currents through red resistors, no V1 , V2 has no effects on V01, only +5V from the top down through the resistor of 10k to V01.
V01 = 5-VR(10k).
Status
