Okey, so when it goes from infinite to -infinite then this zero like here :Notice that when Z_T goes to positive infinity, there is a frequency at which it transitions very sharply to negative infinity. In theory, this occurs instantaneously and there is no frequency in between where it is zero. That zero is an artifact of making a graph that is just connecting dots between closely sampled points. That nearly vertical line should really be perfectly vertical and should be dashed to indicate that it is not actual values.
Isn't a zero. But isn't there a frequency very small like 36,00000001 Hz that makes it equal 0 reactance in this point ? From this transition from infinity to - infinity ?
But what does - infinite indicates ? - infinite is also a resonance ?
So basically there are 2 zero ?
Also I asked you what does the circuit sees.
If the total reactance is 0 then it looks like that ?
also how would it look like in equation ?
Z = R +jX right ? so Z = R + j(infinite) ? and Z = R + j(0) ? If yes then how from Z = R + j(infinite) I get Z = R or how from Z = R + j(0) i get Z = 0 because all current goes through this short circuit. Or am I again miss understanding something ? Because this is what the resonance is showing right ?
Edit :
Also in post #35 I've mentioned that some users looked at this complex circuit using series resonance or parallel resonance. But you mentioned that I should be looking at it like that. So how is it exactly ?
EDIT 2:
I tried the same thing do in a simple example (the same way you have calculated things).
I've used some ready to use equations because this is simple parallel resonance. It is not a complex circuit so I could use simple equations.
so the resonance frequency should be 40 Hz. But how do I read it in this diagram which is the resonance frequency ?
And how to I write is as an equation ? Z = R+jX ? = parallel resonance = > Z = R + j*infinite ?
Also when I give it into simulation the voltage source doesn't sees this circuit as a pure resistive https://tinyurl.com/2lrjm72c but the phase is shifted. Even though this is a 40Hz resonance frequency.
