CAN Node Identifier and Message Identifier
electronicsLearner77
Joined May 26, 2012
127
Suppose i have a Engine ECU with CAN ID 0x300 and it is transmitting some 3 TX messages what will be the relation between the CAN ID and the Tx messages? I mean to say all the Tx Messages should have an ID. So they will be something like 0x300, 0x301,0x302 etc. Please help.
Papabravo
Joined Feb 24, 2006
22,116
CAN Identifiers are NOT connected to a particular node UNLESS a higher level protocol than CAN mandates such a connection between CAN identifiers and Node address. I could write you chapter and verse on how you might or might not want to do this. If we don't have a higher level protocol than CAN involved then a designer is free to whatever she wants.
