Can my 1.5 watt solar panel charge an AA battery?
Jules22
Joined Oct 22, 2021
Hi There Knowledgable Ones!
Just to see if it can be done. I have a solar panel outputing 1.5watts ( I do not know the voltage). This powers a small fountain and works really well on sunny days. I had this idea that if I put a rechargable battery (AA x 1, 2 ?? - your advice) in-line, it could be recharging in the daylight hours (and run the fountain) and then the battery (s) could take over for a period of time when it was "dark".
Sorry if this sounds idiotic, but Im not an elecronics guy. Your advice/info woud be appreciated.
Tks Jules
BobTPH
Joined Jun 5, 2013
11,665
If you just put the battery in parallel with the fountain, the fountain would most likely stop. You need to measure the voltage and current if the operating fountain. Then we could tell you if it is feasible and how to do it.
Bob
Ya’akov
Joined Jan 27, 2019
10,355
Welcome to AAC.
It’s not idiotic but it may be impractical. The 1.5W rating of the cell would be for full sunlight. You’d need to determine the load presented by the fountain, and the load of charging the battery. It is most likely attempting to charge the battery at any reasonable rate would prevent the fountain from operating.
You might be able to add a solar cell and dedicate it to charging the battery.
In any case, you need to know how much power the fountain needs to operate.
[EDIT: typo repair]
Ya’akov
Joined Jan 27, 2019
10,355
Bob
Beat me by this much.
