little update: I got some new gate drivers and hooked up the circuit as discussed in this thread.
The result was that my converter fried again, but my gate-drive opto made it out alive - thanks to the gate resistance which i forgot last time.
The circuit works fine when the fet is unloaded. By that i mean that i can see the gate drive waveform behaving nicely without my bulb connected to the drain.
Using my scope i can see the rise is much sharper with the gate driver and the time before passing the miller plateau is greatly reduced compared to driving the gate with a v-divider.
Seemed good so far.
When i connect the bulb to the drain however, then increase the duty - the lm2596 chip on my board smokes. But as i said, unlike before - the opto made it out alive.
I had the input of my converter connected to a cap that is charged to the peak value of my 25V rms supply which is causing the issue i believe.
Is it reasonable to believe that the effect of the load switching is causing a voltage spike which is frying my converter?
The switching frequency is 20kHz, so am i switching at a speed that doesn't allow the loading effect on the transformer to reach equilibrium?
Seemed good so far.
