can I use one transformer for two power supplies, and will the grounds be connected?
schmitt trigger
Joined Jul 12, 2010
2,276
For the thermal and SOA protections alone, an integrated solution may be the best approach.
Having said that, if you want to proceed with a discrete solution, by all means do. It is a good learning experience.
28,502
The first place to do any experimenting is ON PAPER!! Draw out the actual circuit, and then exaine it for unintended current paths. To make that method more reliable, avoid using "Ground" symbols, show that actual "ground" connection!
In this thread, already, one of the ideas DID include a difficult to spot shorted circuit, that put one rectifier diode directly across a portion of a transformer. Fortunately it was discovered before being built.
