can I use one DC 5V to power 3 identical cameras?
thor21
Joined Sep 29, 2024
435
@MrChips i think i was told some time ago,
that if u have for example 12V 5A, and two different devices lets say 12V 1.4A, 12V 1A ... its not a good idea to connect them both on one PSU.
thanks
35,268
thanks
I don’t know where you got that misinformation.
If all the devices require the same voltage then you can drive them from the same PSU. It would have to be a very special case where this was not recommended.
dl324
Joined Mar 30, 2015
18,490
A statement saying it must/will work or might/won't work needs to be taken with a grain of salt.
You say the cameras draw a maximum of 1A. That means they might not ever draw that, or anywhere near that, under actual operation.
If they actually draw 1A and you feed them with a long, small diameter wire, there could be voltage drop that could affect operation. I had this situation for a 12V security camera with a long-ish cable that carried video and power (in separate wires). The power cable was such a small diameter that there was a couple volt drop at the camera that made it unreliable. I ended up using a dedicated 14.4V supply for the camera in question.
You could use a single 5V/6A supply for the 3 5V/1A cameras as long as voltage drop in the lines you run to them don't cause a voltage drop large enough to affect operation. Most would probably assume that you knew that...
thor21
Joined Sep 29, 2024
435
@dl324
thanks, yes i am aware of the Voltage drop thats why i went for 5V psu from meanwell where u can set it to 5.5V and using wire for calculated distance at the end u have 4.9-5V.
So does it mean that i can attach only similar 5V devices on that PSU ie 3x Camares, or i can attach also different 5V device?
Assuming the total sum of max A (of all devices) < PSU max A.
thanks
35,268
There are two concerns mentioned in those posts:
1) Supply noise and instability
If you have a device that draws a lot of current on initial turn on or while switching a large load, you might experience brown outs on the supply rail. A good quality power supply must be able to supply temporary surge current.
A device could conceivably generate a lot of electrical noise that can propagate through the power rails. Every device should provide its own internal EMI filters. For example, all automotive 12 V electronics must be designed to suppress EMI coming from the automobile’s ignition system.
2) Isolation
Conceivably, some devices require positive voltage on the PSU center pin while others require negative voltage. This is not a problem if there are no interconnections between devices. If devices share a common ground, you need to check that the power adapter and signal connections are compatible.
Note: Not all wall adapters are floating. You need to check for compatibility between devices and power adapters if the adapters are not isolated.
dl324
Joined Mar 30, 2015
18,490
The problem with using an adjustable power supply to compensate for voltage drop is that all of the devices will use that same voltage. If the wire lengths are different, then each device will have a different voltage drop.
Also note that the individual 5V devices should have a voltage tolerance.
Assuming total sum of max A (of all devices) < PSU max A.
Any combination of 5V devices can be powered from the same power supply as long as you consider voltage drops in the individual power lines and don't exceed the current rating of the supply.
If one or more of the devices feed noise onto the power supply, that could be problematic.
thor21
Joined Sep 29, 2024
435
2) Isolation
Thats what i do not understand.
whats PSU center pin? I have PSU which has +/- ... and i create separate wires to the endpoint devices ; so +/- is provided correctly.
what do u mean by interconnections between devices?
IF u have one PSU with +/- ... and u attach 3 devices to it ... all will share same ground (-) from that PSU?
thor21
Joined Sep 29, 2024
435
yes thats okay, and i know that its limitation parameter.
ie if devices is low cost it can feed noise onto the PSU and affect all other?
Tonyr1084
Joined Sep 24, 2015
9,744
I have a home security system that features 12V cameras that are wired. Each camera is powered from a dedicated wall wart (WW). To save 110VAC plug space I found a larger 12V supply that had ample power to run all the cameras. However, when I ran all four cameras off a single 12V supply they still worked but the video quality was horrible. Not sure how to describe it but imagine 50 glass rods (round rods) all lined up across the screen from bottom to top, then look at the image behind the rods. The rods act like lens's and distort the video. Only when each camera was powered via its own source did it work properly. I even tried applying filter caps to smooth out whatever was causing the ripples but even that had no effect. To this day I don't know why it does that - but it does. Four cameras on a single supply doesn't work well for me. No idea why!
thor21
Joined Sep 29, 2024
435
@Tonyr1084 assuming the PSU max A was still higher that sum (each_camera max A)
Its weird bc it can imply that in case one attach other devices like Sensors etc... it might affect them?
Wondering if such a devices like that have 2 psu for each USB port or its also 1 PSU output shared between 2 devices?
https://www.se.com/ie/en/product/GG...-charger-2-x-usb-3-1-a-stainless-steel-white/
Tonyr1084
Joined Sep 24, 2015
9,744
Typically devices with 2 USB's have one at 1A and the other at 2.5A. Or something like that. I have plenty of those. I'd imagine that they may have common parts and dedicated parts. The parts that are dedicated to 2.5A are likely isolated from the 1A. But keep in mind, those are for charging. Not necessarily for powering electronics.
The camera draw daytime color draw was less than 2A. Night time black/white w/infrared illumination probably not more than 3A. The supply used was able to power a single camera with no interference. But as soon as I plugged a second camera into it there was interference. The supply total power output was 20A. Almost 50% bigger than the expected draw. But even in daytime without the IR the picture was distorted. Didn't even try to see what they did at night. And remember, the distortion was there with two cameras connected.
Just to be clear: the power leads were connected to common ports. Four positive ports, four negative ports. All four ports (+&-) were common.
