Can i replace axial inductor with smd enclosed type inductor
imraneesa
Joined Dec 18, 2014
227
20180910_103922.jpg Hi,
I found one of the radial inductor bad in the circuit and i found similar value smd type in my box. Can i replace it with the one i found. i am attaching the image of both inductors. Thank you.
Best Regards,
Imran
ericgibbs
Joined Jan 29, 2010
21,423
hi,
I would say yes, make sure the SMD inductor connects to both sides/faces of the PCB as the hole thru type.
May require a wire link thru.
E
noweare
Joined Jun 30, 2017
115
Inductance alone does not say it all. A open magnetic circuit can handle a lot more dc and not saturate compared to a closed magnetic circuit.
Janis59
Joined Aug 21, 2017
1,894
They may have harshly different saturation current. Thus, it ought be measured, the inductance versus DC bias current. If i(sat) are similar and L are too, then both are equal.
