Can I repair a zapped UNO R3?
Terrypin
Joined Feb 5, 2016
113
Carelessly I applied 12V to the 5V pin while breadboarding a project. :(
I now get no signs of life from the board. And applying 9V via the board's jack socket from my bench power supply indicates a direct short.
I've placed an order for a replacement board but, expense apart, it seems such a waste. Is there a fuse anywhere or anything else I can try to repair it please?
(I've posted simultaneously here and to the arduino.cc forum.)
Terry, East Grinstead, UK
Terrypin
Joined Feb 5, 2016
113
Thanks Eric. I fear you're right.
In case it offers a further clue, with the 328 chip removed both the 5V and 3.3V pins are grounded. I see nothing visibly wrong on either top or bottom of the board. I was just wondering if it would be worth replacing the 3-pin regulator chip next to the jack socket, an AMS1117?
I expect delivery of a replacement UNO R3 tomorrow.
Must redouble my caution, or this could become an expensive hobby!
dl324
Joined Mar 30, 2015
18,467
You probably took out both microcontrollers too.
Use this as a learning opportunity and don't make that mistake again.
narkeleptk
Joined Mar 11, 2019
599
Maybe try to power up the 328 up on breadboard see if he's dead or not. Probably so, but still a fun project if you have time to burn.
When your new one comes in you can use it to compare the bad one and easily trace out your faults using a dmm or curve tracer. Again, as a fun project.
