Can I know Op-Amp which has +/-120v or more V total swing?
dl324
Joined Mar 30, 2015
18,490
You can add circuitry to make more typical opamps do that:
I've seen a circuit where they adjust the power rails based on the output voltage so the opamp never sees a higher supply differential than specs allow.
These are lethal voltages. What is your application?
Ian0
Joined Aug 7, 2020
13,306
