I have a ucontroller powered through an AP2112 3.3v from 5v, but I already have a stable3.3v so here my question,
can I just feed 3.3v on the output pin 5 of the ap2112?
if I understand the ic when turn off have inside discharge resistors is this really, 60Ohm or is it going into some High resistor?
if I do that will I blow the AP2112 ?
I try to measure the input current ... I should see 55mA but no im more like 20mA who is the uctrl running...
I could not really understand the spec sheet on that...
