Can exist different pinout for a transistor with same part number?
studiot
Joined Nov 9, 2007
4,998
I can't think of a TO-92 transistor I've ever used that didn't have the base on pin 2.
What a strange thing to say.
In my stock I have
European BC639 & BFR40, both b-c-e
American MPSH10 c-e-b, TIPP31 b-c-e
Jananese 2SC1318 b-c-e
This is only a quick look at NPN ones.
Edit @ Bertus I should have a quick re-look at the data you posted.
ian field
Joined Oct 27, 2012
6,536
In my stock I have
The RF version of the transistor family that preceded the BC547/557 variety had the emitter in the middle.
AFAICR; the BC147/157 had the standard EBC layout - the RF parts; BF194/195 were BEC.
studiot
Joined Nov 9, 2007
4,998
Its just that I also noticed I have a hundred or so BC157 (PNP) in my stock with e-c-b
These are the 'push-fit' ones if I remember correctly, though it's a long time since I've used one.
ian field
Joined Oct 27, 2012
6,536
Those lockfit transistors are NASTY!
They're a PITA for mounting on stripboard and if you try to graft lead extensions on, they just snap off.
When I started building up my junk box, there was a plague of those things! As soon as I could get hold of transistors with proper leads, I had a big clearout of the lockfits.
There might be a small handful of RF types in a tobacco tin somewhere.
