Can anyone tell me with this isn't working?
ericgibbs
Joined Jan 29, 2010
21,569
hi Halsey,
Welcome to AAC.
If pin #7 of the 3905 is holding up/down of the 555 pin 2 trig it will not work.
Use a connection cap 10n from pin 7 to pin 2 and a 10k pull up on 555 pin2.
E
Correction pin#7 of the 3905.
Halsey
Joined Mar 4, 2018
30
hi Halsey,
Welcome to AAC.
E
Is there a diagram I could see?
ericgibbs
Joined Jan 29, 2010
21,569
hi,
Look at this, I am assuming that 3905 Timer output goes low at the end of the time period, if not ,you need a transistor inverter.
E
EDIT: Added the transistor version
Halsey
Joined Mar 4, 2018
30
hi Halsey,
Welcome to AAC.
E
hi,
E
Thank you very much for your assistance.
LesJones
Joined Jan 8, 2017
4,543
Hi Eric,
I think you may have misinterpreted the TS's requirement. My understanding is that he wants the 555 to give a burst of pulses with the duration of the burst of pulses controlled by the 3905. His schematic and yours seem to be triggering the 555 in monostabe mode giving a single pulse when the 3905 times out . Pin 2 will need to be connected to pin 6 for astable mode. I would think using the output of the 3905 to gontrol the 555 via it's reset pin would probably do what he wants.
Les.
ericgibbs
Joined Jan 29, 2010
21,569
hi Les,
You could be right, I assumed he was trying to trigger the 555, by using pin 2 Trigger.
I wonder where he got that circuit.?
E
AnalogKid
Joined Aug 1, 2013
12,268
a 7555 CMOS in astable mode
First, your 555 circuit is not an astable oscillator. The 7555 datasheet has two different circuits for this. I think you should correct your 555 circuit first. Only then will any kind of control circuit work for you.
ak
Alec_t
Joined Sep 17, 2013
15,156
10Meg and a 360uF electrolytic are asking rather a lot of an accurate timing circuit, because (a) the current through the resistor is likely to be of the same order as the leakage current of the capacitor and (b) circuit board contaminants will be in parallel with the resistor.
Halsey
Joined Mar 4, 2018
30
Sorry, the 3905 is supposed to trigger the 7555 CMOS in astable mode for a duration of one hour. The load is going to be earphones and LED lights.
Halsey
Joined Mar 4, 2018
30
The 3905 Timer was chosen for its precision which it has allegedly for up to several hours,as well as being immune to fluctuations in the power supply which will have no effect on its acuracy. It can't really operate well in astable mode though.
35,172
It is still not clear what you are trying to do.
Do you want the output to last for a duration of 1-hour?
Or do you want the output to be triggered at intervals of 1-hour?
How long does the output last?
What does the output do? Flash or oscillate for how long at what frequency?
AnalogKid
Joined Aug 1, 2013
12,268
Once you have corrected your 555 astable circuit to be the same as one of the circuits on the datasheet, connect 3905 pin 7 to 555 pin 4. Do NOT connect 555 pin 4 to pin 8 or Vcc. When power is applied to the circuit, the 555 will oscillate for 1 hour and then stop.
Note: You must add a 1K resistor from 3905 pin 7 to GND.
ak
Halsey
Joined Mar 4, 2018
30
The 3905 is to trigger the 7555 CMOS at 40Hz astable for 1 hour.
Halsey
Joined Mar 4, 2018
30
The 20K Ohm trimmer is 20 turn to adjust it to 40Hz to a value of I think 13.5K Ohm to get an even sqaure wave.
