Can anyone show me how to work out the current flowing through the 32 ohm resistor using kirchoffs law and another method?
Ramussons
Joined May 3, 2013
1,568
2 steps.
Replace 5 volt battery with a wire. Calculate I_32_ohm. ----- 1
Replace the 12 volt battery with a wire. (Restore the 5 volt battery !). Calculate I_32_ohm. ------2
Add 1 and 2. Thats it.
RBR1317
Joined Nov 13, 2010
715
To find the current flowing through the 32 ohm resistor you need to find the voltage across the 32 ohm resistor. So ground one side of the 32 ohm resistor, then label the other side as Vx. Solve for Vx using Kirchoff's Current Law (the sum of the three currents flowing at node Vx must be zero.) Note that in the attached diagram the components are slightly re-arranged to make it easier to visualize the currents that are flowing. This approach to getting a solution might also be called Nodal Analysis.
The Electrician
Joined Oct 9, 2007
2,986
What software did you use to create your schematic?
