What software did you use to create your schematic?To find the current flowing through the 32 ohm resistor you need to find the voltage across the 32 ohm resistor. So ground one side of the 32 ohm resistor, then label the other side as Vx. Solve for Vx using Kirchoff's Current Law (the sum of the three currents flowing at node Vx must be zero.) Note that in the attached diagram the components are slightly re-arranged to make it easier to visualize the currents that are flowing. This approach to getting a solution might also be called Nodal Analysis.
LibreOffice Draw. For simple schematics I usually take a screenshot then crop the image with GIMP; otherwise, print as PDF. My favorite font for labeling drawings is Lucida Fax. Over the years I have created a library of symbols as I needed them.What software did you use to create your schematic?
