hello everyone,
i am trying to interface at24c32 eeprom which is given with ds3231 rtc module.
here is my twi.c file
here is how m accessing twi
and i am using following address
but i am not able to get the result. please help.
thank you
Mod edit: code tags
C:
void Twi_Init()
TWSR=0x00;
TWBR=0x46;
TWCR=0x04;
void Twi_Start()
TWCR = ((1<<TWINT) | (1<<TWSTA) | (1<<TWEN));
while (!(TWCR & (1<<TWINT)));
void Twi_Stop(void)
TWCR = ((1<< TWINT) | (1<<TWEN) | (1<<TWSTO));
_delay_us(100) ;
void Twi_Write(uint8_t value)
TWDR = value ;
TWCR = ((1<< TWINT) | (1<<TWEN));
while (!(TWCR & (1 <<TWINT)));
uint8_t Twi_Read(uint8_t ack)
TWCR = ((1<< TWINT) | (1<<TWEN) | (ack<<TWEA));
while ( !(TWCR & (1 <<TWINT)));
return TWDR;
C:
void ds3231_EEP_WriteData(unsigned char MEM_Address,unsigned char value)
unsigned int temp;
Twi_Start();
Twi_Write(DS3231_EEP_W_Address);
temp = MEM_Address >> 8;
Twi_Write(temp);
Twi_Write(MEM_Address);
Twi_Write(value);
//value = DecimalToBcd(value);
Twi_Stop();
_delay_ms(20);
unsigned char ds3231_EEP_ReadData(unsigned char MEM_Address)
unsigned char TwiStatus;
unsigned int temp;
Twi_Start();
Twi_Write(temp);
Twi_Start();
Twi_Write(DS3231_EEP_R_Address);
TwiStatus = Twi_Read(0); // nack
//TwiStatus = BcdToDecimal(TwiStatus);
Twi_Stop();
return TwiStatus;
C:
#define DS3231_EEP_Address 0xA0
#define DS3231_EEP_W_Address DS3231_EEP_Address | 0x00
#define DS3231_EEP_R_Address DS3231_EEP_Address | 0x01
thank you
Mod edit: code tags
