Camera circuit to usb (OV2640)
Carsen -W-
Joined Jul 13, 2019
Hello, I am really new to circuits and such and am trying to see if there is a way to connect an OV2640 circuit board to work like a webcam of such.
I provided the board I should be using as a picture and its schematic as a pdf. If anyone could give some info on where I should connect wires to get signal through usb. Thanks :)
Wolframore
Joined Jan 21, 2019
2,619
They make a usb version. In order to stream video you will have to compress and convert to usb serial data. Your device is built for parallel output. You will need to add FTDI chip or another option might be to send the data to a raspberry pi then have it convert to usb. Anyhow it would be much easier to just get the ov2640 that’s built for usb.
