Bypass capacitors breadboard
Tony Elliott
Joined May 8, 2015
160
image.jpeg image.jpeg image.jpeg Hi All,
Here is my Voltage Controlled Amplifier breadboard and schematics. Do the bypass capacitors look right place to you. The schematic is fairly vague on this so this is how I interpreted it.
dl324
Joined Mar 30, 2015
18,524
There's usually so much stray coupling on breadboards that it's not practical to even worry about supply decoupling.
When you transfer the design to a PCB, put a decoupling on the power pins of every IC.
