I have an update on this type of power supply.Watch out for these on Ali Express:
If you need 3V, the ones I bought will only go down to about 3.6V. They do appear to be able to source 3A though...
There is no specification given for accuracy or regulation. They are recommended for DC motor speed control or light dimmer, etc. So, for the price, they are a pretty good deal.I have an update on this type of power supply.
I bought these from two different sellers, so it's a design issue.
I had the same concern. I'll check the capacity of a couple of the batteries in a few months and let you know.I was going to use those 9V lithium replacements but I don't know their self-discharge i.e. would it be OK 3 months from now or would it be dead, boost converter running all the time I think.
I'm of the opinion that feedback ratings have little meaning. Most of the feedback for the batteries I bought wasn't helpful. Some said they'd report back if there are capacity issues, but none did and the 5 star ratings remained. Most of the feedback didn't have comments.That store has only been open since Feb and 87.1% is a dismal review score. I go with higher rated stores, high 90%'s and open for a longer time period.
It seems that a reasonable capacity in that form factor is more like 600mAh. I have some EBL rated at 600mAh and they provide that capacity. But the output voltage is around 8V.12800 milli amps hour from a 9V battery? Seriously?
Perhaps they actually meant 12800 micro-amps hour.
The ones I really liked were the ceramic breadboards. They were made much more precise than the plastic ones and didn't melt from a hot component.
Indeed, the previous ceramic models lacked this feature as well. They utilized a distinct two-row version that had slightly reduced dimensions.
Which store and vendor did you bought was it online purchase? Did you track the order?Why aren't we mentioning the Ali store names that sell fake semi's?
I bought ADC TC835 from liaoxiyuan/SICSTOCK and they ran fine for about 2 minutes, then shorted.
Bought a bunch of JFETs from shenzen IC store, like always there is only one laser in china doing all markings so they look vanilla but appear to work OK. I have to do more tests on them. TO-92's the leads are only plated up near the body.
2 of 8 were discharged after a little over 1 month.I was going to use those 9V lithium replacements but I don't know their self-discharge i.e. would it be OK 3 months from now or would it be dead, boost converter running all the time I think.
Good offer! I know they do not have 9900mAh capacity. I used to order such items and used to open disputes with test videos. So I used to get a partial refund and the final cost was too cheap.Another fake 18650 9900mAh:
