I started the AC, and smelled burning bakelite plastic, nasty smell.
The potential relay never opened the start circuit, so kept blowing the breaker open.
Opening up the relay box, there is a coil. The coil due to back EMF as the electric motor spins up is supposed to pull in and open circuit the start capacitor.
It looks like the way this is made, they rivet the screw lug to the inside lug connected to the coil and the riveting mechanism rusted, built up high resistance and could not connect internally to the coil. This is the 3rd potential relay in about 10 years that has failed. In past times when the relay fails, the start cap would blow, explode, but the last time I bought a 330 vac start cap so it does not blow anymore, but it does get hot!
So I ordered another relay, this one I plan to solder the rivet to the interior lug connection that hooks up the coil wire. And solder the rivets connecting to the start capacitor wires. And also dip the whole thing in engine oil as an attempt to keep it from corroding on the inside.
This is a MARS 65 relay, made by Mars and it is garbage they way they make them, they plan them to blow up on you, that way they keep on selling another part.
So much current flows through the start wires, they overheated and burnt up the bakelite and the interior was severely overheated. Pictures shows damage, and I had started to loosen the screws too. The bakelite fell apart in my hands.
It had worked fine for 2 years till yesterday. The rusted screws are not internally connected, just a neutral connection point.
The 2 screws on the right form the start capacitor circuit.
The double twisted wire connects to the coil, (why it is 2 wires is beyond me, but someone did that)
The internal relay contact points were fine.
No connection except for riveted connections inside the relay box. A fail, from a consumer viewpoint, a success from a manufacturing and sales viewpoint. Overheated screws bake off the zinc plating, then the crews easily rust, the whole thing will rust inside and develop high resistance, high resistance makes lots of heat with lots of amps flowing, and it self destructs, burns up, success! , another sale made, money keep flowing in to MARS, GE , etc....
One year I tried a universal electronic relay, it worked for about a year, then failed some semiconductor device.
