Building all pass filter
DaniKowa
Joined Sep 23, 2020
218
please some question for you.
1) Supposing ti build a all pass filter to correct a phase signal (ex -90° to 0°or -180) .Is this correction is still fixed for all frequencies passing through the filter or not?
2) Is this filter buildable with discrete components instead the opamp?
38,885
No, it varies with frequency.
Yes.
But the opamp circuit will likely give a more ideal response.
Below is the LTspice simulation of an all-pass op amp filter:
Note that the phase varies from 180° to 0° as the frequency increases, while the amplitude is essentially constant.
If you interchange R1 and C1 the phase will vary from 0° to180° as the frequency increases.
DaniKowa
Joined Sep 23, 2020
218
Ok a will try to simulate. I'im not sure but sometime ago have found a circut made by two opamps that permit to vary the phase with two resistor instead one resistor and one capacitor. May be possible? Thanks.
