Build a simple 5 volt charger
koklim1138
Joined May 5, 2023
9
I'd build a simple voltage divider charger with 1 Amp diode from 4.8 AC - DC adapter (500 ma - output volatge - 4.15Volt) to charge my two AA battery.
My Battery finished charged was 1.25 (Sony 4600mAh), but it can only be used within half day.
I suspect It may not enough to charge in capactity charged.
Does it required to add low capacitance of Capacitor + 1 Amp diode for quickly release current into my battery for charge?
Thanks appropriate to all helps.
Ya’akov
Joined Jan 27, 2019
10,294
Welcome to AAC.
It is very hard to follow your post. I assume that English is not your first language, are you using a translator (like Google Translate)? If not, you might try that so you can write your post in your mother tongue with your entire vocabulary. The translation might be better.
In any case, trying to decode your post, I have the idea you are saying that you charge the two cells to 1.25V each (I assume these are NiMH), and then they self-discharge within a days.
If that‘s the case, then no, it can’t be the charger. If the cell is at 1.25V then it is at least partially charged. It may not have the full capacity if you try to discharge it through a load but concerning self-discharge, the state of the charge won’t effect it.
It sounds like defective cells, are they old?
Alec_t
Joined Sep 17, 2013
15,156
Welcome to AAC.
Generally, a voltage divider is not the best option for a charger. Post a schematic of your charger, showing how/where the components are connected. Also, post links to the adapter and battery adverts, or pictures of their labels. Be aware that there are counterfeit Sony batteries being sold. Did you buy yours from a reputable source? If a fully charged cell self-discharges in half a day it is a fake or defective.
seanstevens
Joined Sep 22, 2009
323
A charger is not as simple as that, depending on the battery type and there are many types of batteries. Generally they are constant current and your voltage devider is not.
You need to know the basics of reghargable batties and their charging methods or you will run the danger of your battery exploding or catching fire. You should not be doing this if you are not sure of what you are doing.
Audioguru again
Joined Oct 21, 2019
6,826
Sony or any other manufacturer does not make an AA 4600mAh Ni-MH battery. They are all 2500mAh so you got fakes.
A dead battery cell is 1.25V and it begins to charge at 1.3V and is fully charged at 1.4V to 1.5V.
You need a proper charger to charge them, not a voltage divider.
koklim1138
Joined May 5, 2023
9
yes, the battery is 1.3 under fully of charged. Maybe I'll take down the voltage divider and build a low capacitance of capacitor with 1 A diode in series and I should head to back to check the amperage of DC current before build up.
