"Simple" and easy schematic to build a variable (0 to 3V) Voltage Reference
Houseman
Joined Sep 25, 2018
22
Hi all.
After snooping around a little bit I need short hints to build a "easy" voltage source to output 0,6 to 3V selectable by a trimpot beginning from a 12V input, with a current of a couple of mA (5mA). Accuracy and temp stability should not be an issue. I have seen different Vref IC from Analog Devices but I was wondering if an old fashion couple of transistors or better MOS could be the circuit.
Where should I point the direction to?
Best regards and thanks.
Ya’akov
Joined Jan 27, 2019
10,307
Hi all.
Welcome to AAC.
What is the application for this circuit?
Houseman
Joined Sep 25, 2018
22
Hi. Thank You for Your quick reply. I have an IC (Infineon's IL6150) that is a LED driver. It accepts at PIN2 an external analog voltage from 0,6V to 3V to steer its internal PWM generation acording to this picture in the datasheet:
Alec_t
Joined Sep 17, 2013
15,157
..... or perhaps an 'amplified diode' :-
Edit:
My reading of the datasheet for the ILD6150 is that the PWM pin sources current (~12uA). So I doubt your reference needs to supply 5mA.
Houseman
Joined Sep 25, 2018
22
thanks alot. i didn't realize how simply with the 3.3V!!!! btw I know that it needs less than 5mA but, as far as I had experienced by measuring in the lab by prototyping, connecting a variable psu and helding current to 1mA @2.5V i didn't manage to steer the pin correctly.
When an input pin Sources current do you think that also connecting a R=(4.3V/12uA) trimpot directly to the output would do the rest? best regards again.
