I am having problems with part b of the question i have working on. For part a) I have managed to find that the circuit is a Buck Converter (Step down converter) and that duty cycle is controlled by a OP AMP in comparator mode which creates a error voltage and is fed into the oscillator. ( I have included more information about the two states of the circuit, when the transistor is on, and when the transistor is off, included the free wheel diode etc, and the indoctors magnetic field collapsing).
For Part b), i am getting stuck, i take it you have to start at the voltage divider and try and work out R2. I have started this with the equation
\( V_{REF} = (\frac{R2}{R1 + R2} ) * V_{cc} \)
which re-arranges to
\( R2 = (\frac{V_{REF}}{V_{cc}} - 1) * V_{cc} \)
With Vcc being the voltage supply to the OP AMP which isn't supplied.
I have read that the value of R2 can also be given by the
\( R2 = \frac{V_{fb}}{I_{r1/2}} \)
With V_fb being the voltage to the non inverting input of the OP AMP, but also the current is not supplied for the equation. The current being the current going into R1 at the top of the voltage divider.
I am a little bit stuck, if anyone can point me in the right direction. Hopefully it is something simple i am missing! Or if i haven't explained myself very well!
Thanks for your help
