why can't i get more than 8 voltage in proteus for buck converter?. i increased duty cycle up to 100% however the output is constant at 8v
this configuration limits the output of the buck converter so how to make the VGs independent of the power supply on drain.?Your MOSFET is connected common-drain (a source-follower), so the gate voltage must go to at least 5V above the positive supply to switch it on fully. The gate must be at least 5V above the source to switch it on, and when it is switched fully on the source will be at the positive supply.
Generally speaking a P-channel MOSFET has a larger die area with slower switching characteristics and slower switching.this configuration limits the output of the buck converter so how to make the VGs independent of the power supply on drain.?
I have already used high side driver 2110 and the same problem exists. The driver supply must be higher than the mosfet drain supply .which mean that if the buck input is 100 v the ic driver VCC should be higher than 100vEither:
1) Use a P-channel MOSFET
or:
2) Use a high-side driver IC
The IR2110 contains a charge pump which lifts the gate voltage above the VCC supply. (The Vb voltage)I have already used high side driver 2110 and the same problem exists. The driver supply must be higher than the mosfet drain supply .which mean that if the buck input is 100 v the ic driver VCC should be higher than 100v
I used ir2110 in proteus and the same problem existsThe IR2110 contains a charge pump which lifts the gate voltage above the VCC supply. (The Vb voltage)
Did you remember to put the diode in?I used ir2110 in proteus and the same problem exists
