buck converter in proteus simulation
mah
Joined Mar 15, 2010
393
why can't i get more than 8 voltage in proteus for buck converter?. i increased duty cycle up to 100% however the output is constant at 8v
Ian0
Joined Aug 7, 2020
13,199
Your MOSFET is connected common-drain (a source-follower), so the gate voltage must go to at least 5V above the positive supply to switch it on fully. The gate must be at least 5V above the source to switch it on, and when it is switched fully on the source will be at the positive supply.
mah
Joined Mar 15, 2010
393
this configuration limits the output of the buck converter so how to make the VGs independent of the power supply on drain.?
Papabravo
Joined Feb 24, 2006
22,096
Generally speaking a P-channel MOSFET has a larger die area with slower switching characteristics and slower switching.
A high-side driver IC will boost an existing logic control voltage to a higher level so that an N-channel FET can be used in this application. Of course sin this is a buck converter you could easily derive the gate voltage from the input voltage. Be careful not to exceed any limitations on Vgs listed in the datasheet
mah
Joined Mar 15, 2010
393
Either:
1) Use a P-channel MOSFET
or:
2) Use a high-side driver IC
I have already used high side driver 2110 and the same problem exists. The driver supply must be higher than the mosfet drain supply .which mean that if the buck input is 100 v the ic driver VCC should be higher than 100v
Ian0
Joined Aug 7, 2020
13,199
The IR2110 contains a charge pump which lifts the gate voltage above the VCC supply. (The Vb voltage)
