Roderick Young
- Joined Feb 22, 2015
- 408
I like AnalogKid's suggestion of simply buying something based on the 2596HV. That's what I would do.
However, if you still want to build your own, this is what I meant by putting the MOSFET in the ground wire. This allows you to still use an N-channel, which is cheaper and better, without the need for high-side (exceeding +48V) drive. The driver chip is probably overkill, just one that I remembered off the top of my head - you can likely get by with a much weaker driver.
Generating the +10 volts for gate drive could be as simple as using an LM317AHV with 48 volts in, since efficiency is not a concern.
