Buck,Boost,Inverting Converters
Raikiri
Joined Mar 22, 2009
16
I've attempted this but I'm not sure if I have the right answers or not, questions are as follows:
For all three circuits,
My answers were as follows:
1) Vin = 0.533V
2) Vin = -130V
3) Vin = 7.677V
thanks for your help!
t_n_k
Joined Mar 6, 2009
5,455
Without actual circuit values other than Vout=7V and duty cycle=21%, it's hard to give a answer ..
Since first circuit is a buck type I would expect Vi to be greater than Vout - 0.333 volts seems wrong - maybe you meant 33.3V
Second is a boost type - at 21% duty cycle expect Vin to be only slightly less than Vout - say around 6V. I doubt -140V is correct.
Not sure about the third - you could try a simulation and watch what happens with parameter changes. It's obviously negative output with positive input - buck behaviour? Say Vin=30V ????
No simulator?
http://focus.ti.com/docs/toolsw/folders/print/tina-ti.html
or
http://www.simetrix.co.uk/ - limited no. of nodes in freeware schematic
