Buck-Boost DC DC converter LiPo battery
Tom_26
Joined Mar 23, 2018
18
I am thinking of using a buck-boost DC-DC converter to charge a nominal LiPo battery. Besides the care that needs to be taken not to overcharge a LiPo battery, the issue I am having is whether or not a negative voltage (supplied by the buck-boost) is adequate for charging. Do you think if by reversing the battery terminals, the ground terminal will be x amount of voltage lower than the positive terminal and therefore work?
Audioguru
Joined Dec 20, 2007
11,248
What limits the charging current?
What detects the charging current dropping as the battery becomes fully charged and disconnects the charging so that over-charging does not occur?
Why are you asking about simple polarity? If it is backwards then the battery will explode and catch on fire.
Why aren't you using a charger IC made to charge a lithium battery properly?
ebp
Joined Feb 8, 2018
2,332
If by buck-boost you mean The Treacle-Fired Crumpet Toaster then yes, you can do it. I think the circuit to which you refer is an inverting converter, which is commonly called buck-boost, though it is neither buck nor boost, hence my preference for a misnomer that is at least conspicuously inappropriate. I assume your interest in that topology is because your input voltage may be either less or greater in voltage magnitude than what is required to charge the battery.
Properly implemented, it can do accurate voltage regulation. Accurate current limiting is less easy. Be sure not to try to have different "grounds." If you need to isolate the input from the output so you do have can have separate grounds, that can be done by using two windings on the inductor, to produce what is usually called a flyback converter (function is identical except that the inductor is charged with one winding and discharged with another).
