buck boost converter
roboticmrl
Joined Mar 3, 2017
hi...
i want make a buck boost converter but i need to circuit and equations for components(inductor and capacitor)...
so..my_data:
input_voltage:10.6 until 12.5
output_voltage:12
output_current:30A
Fsw=50KHz
can you help me??
djb
Joined May 17, 2008
33
If you are still online, please take into consideration that this is relatively not easy task, and it might need the involvement of micro controller.
In general, you will need a buck - boost converter, to be able to step up and also step down according the output feedback.
It seems that you need a more stable 12V power supply. Maybe is easier to take a step back and review a more stable 12V power supply to avoid going the hard way.
Goxeman
Joined Feb 28, 2017
176
You should check in some distributor website and filter what you like, then you start narrowing your results. You will how the datasheet of the product you pick will have all of the information you want and also some component suppliers also have online designs for their components where you can change the values and inmediatly you will see the results
mvas
Joined Jun 19, 2017
539
