Buck-boost converter
38,513
MOSFETs are used because they generally make more efficient switches than bipolar transistors.
Variable resistors are used whenever you want to vary a voltage, such as the output voltage of the regulator.
ian field
Joined Oct 27, 2012
6,536
You have to qualify that statement somewhat - early MOSFETs had high RDSon and wasted more power when switched on hard, than did transistors.
In the interim, they developed the IGBT, it has a MOSFET input and a bipolar output, its basically a hybrid Sziklai pair and the bipolar output is an emitter follower - that makes them relatively slow, so you're basically exchanging conduction losses for switching losses.
MOSFETS can be fast to minimise switching losses - if you drive them properly. The higher the drain current rating; usually the higher the gate capacitance. At high switching speed, you need a driver capable of high peak currents to charge/discharge the gate capacitance quickly.
38,513
Not sure how early obsolete high resistance MOSFETs are pertinent to this discussion. Modern MOSFETs can be readily found with a few milliohms of ON resistance, giving much less ON voltage drop as compared to BJTs.
IGBT's are not only slow, but have a high ON voltage drop, similar to a Darlington, thus aren't efficient for switching low voltages.
shortbus
Joined Sep 30, 2009
10,050
Many of the mosfets that people new to the forum want to use have pretty high Rds/on values. They are in the IRF640, IRF740 ..... family, high by today's standards.
ian field
Joined Oct 27, 2012
6,536
Its not easy to make high Vds MOSFET with low RDSon - so the most evolved parts will still be more pricey.
A while back I tried to find logic level MOSFETs that can handle the back emf from an ignition coil - apparently there's no such thing!
That was some time ago, so things might have changed - but don't bet on them being cheap.
38,513
If you check suppliers, such as Digikey, you should find many MOSFETs with ON resistance of less than 100 milliohms for less than $1US.
Fuji
Joined Nov 8, 2014
100
Why we use MOSFET and variable resistor in a buck boost converter ?
What are the benefits by using these components ?
I think the answer is because it helps the booster to save you power?
Bucks in general should give you around a 94% efficiency.
Shutdown current < 1 μA for extended battery life if your application requires a battery.
They are mainly used where the input voltage can change from VIN - VOUT > VIN to VIN - VOUT < VIN
Definately are being used in smart phones. DC/DC converters are the way to go for batteries in general.
ian field
Joined Oct 27, 2012
6,536
You stated that "high voltage ones" (meaning MOSFETs) are more expensive. My "point" was that it's not unusual for transistors, whether MOSFETS, IGBTs or BJTs to increase in price with voltage. :rolleyes:
When CRTs reigned supreme, sheer volume of production made bipolar transistors up to about 2kV as cheap as chips.
Its when you also want a collector current rating of 12 - 15A that prices start to climb.
There may well be by now, but I've yet to actually see a MOSFET with that voltage rating - and if there is, the RDSon won't be anything to shout about.
