Buck Boost Converter MOSFET Voltage
andrep182
Joined Feb 7, 2012
6
Hi all,
First time posting in this thread, hoping I can get help on a homework I'm stuck with.
Working on a homework on buck-boost, given the following :
  • Vin = 12V
  • Vout = -5V
  • R load = 2.5 ohm
  • Fsw = 20kHz
  • Assume ideal, at CCM
I have calculated more values based on some of the questions it asked:
  1. Duty cycle = 0.2941
  2. Inductor current = 2.833A
  3. Inductor value (assuming delta IL = 15% of IL) = 20.76uH
  4. Capacitor value (assuming delta Vc = 25mV) = 58.82uF
I am having trouble answering the last 2 questions of this HW:
My understanding is that the Vq is the switching voltage. Which means that the waveform should look something like this:
Assuming that, for question 12, the peak voltage should be equal to Vin = 12V. Furthermore, for #13, my guess is the DC component of this waveform should be Vin * D = 2.99V. Of course I got both questions wrong and thus I'm here looking for advice. Not sure how else to go about this logic at the moment. Any help is appreciated, thanks!
38,910
For starters, if you are looking for the peak voltage across the MOSFET, than it has to be more than 12V, since it also sees the negative voltage the inductor has when the MOSFET is off (to generate the -5V output), in addition to the +12V input voltage.
andrep182
Joined Feb 7, 2012
6
Oh right! as soon as the FET turns on again, the potential on that inductor node is still -5V. So it should look like this then?
Which means the peak voltage should actually be 17V?
andrep182
Joined Feb 7, 2012
6
Thanks! Now, comes the next question (about the dc component part). My thought process was that it should be the average voltage of Vq, but I'm not sure how to calculate that. Any hint you can give me?
38,910
Actually the voltage when the MOSFET is off is basically a constant, since although the inductor current is changing, the voltage does not as long as it is pulling current through the diode and charging the -5V output capacitor.
Then to get the average voltage you just take the off-voltage and the on-voltage and use the duty-cycle to calculate the average.
andrep182
Joined Feb 7, 2012
6
How did you calculate the inductor value?
I ask because 21uH sounds small for a switch frequency of 20kHz.
Good catch, and it was a typo from my part, sorry ... Fsw is supposed to be 200kHz. That should make sense now, but in case you're still wondering what I used to calculate it, it was with the following:
L = (Vin*D*T)/(2*delta IL)
MrAl
Joined Jun 17, 2014
13,858
I was going to guess either 200kHz or 210uH :)
Uilnaydar
Joined Jan 30, 2008
118
This thread brought tears to my eyes. TS posted question, full details, and his attempt to work it out. He then engaged all the other folks in the dialog and questions. <sniff> This was BEAUTIFUL!! I would consider it an honor to interview you in the future TS!
MrAl
Joined Jun 17, 2014
13,858
So what is the answer of DC component part ? i tried the (Von*Don)+(Voff*Doff) minus the ripple pf 0.025mV
Do you know what the waveform looks like at the top of the inductor?
For example if it is rectangular when it has a min and max, and since you know the duty cycle and the other side of the switch is at a constant voltage, you should be able to calculate the average DC voltage across the switch.
Does this makes sense to you?
MrAl
Joined Jun 17, 2014
13,858
Have you figured this out yet?
Think about what the voltage across the inductor has to be when the switch is on and with the switch is off when the converter operates in CCM.
Please explain this. I cant understand how to get dc component.
